Hello all:
I am looking for some opinions from the engineers here for a DC power plant design I am working on. This plant will be a nominal 48VDC plant with approximately 200 amp max load, for a small telephone system application.
The basic power plant will consist of :
1. 6, 30 amp AC-DC rectifiers working in parallel operation with load sharing
2. 24 cell Valve regulated battery string with approximately 450 amp hour capacity
The design questions are as follows:
1. Should I build the plant with a fixed earth reference, or let it float. I am leaning to the fixed reference on the positive side of the plant for simplicity sake, but will entertain the possibility of a floating system. Reliability is a key factor here.
2. I want to incorporate some current monitoring into the plant using 200 amp, 75mv shunts, so this gives rise to 2 questions.
a. Measure the current on the negative load side or the positive return side? I have seen it both ways but lately most always on the return side. May not matter in a floating design, but may matter in an earth referenced design.
b. Since I want to be able to monitor current on both the total rectifier outputs AND the total discharge load(s), it seems like I will need 2 shunts. Anyone have any idea how to get both with just 1 shunt?
If you reply, please give reasons (both pro and con) for your answers.
