alisarhangpour
I'm using Atmega16 and I'm going to measure up to 6 different analog signals with its ADC. The problem is, on of these volatges has no common ground with the micro controller and is a DC voltage up to 600V. A precision of around 1V is just enough. What can I do about this? A solution might be to use a seperate ADC chip and send its results to micro but:1.it takes more than 8 pins of the micro, 2.Probably I have to use an array of optocouplers to solve the oncommon ground problem, 3.I might be able to use a serial interface between ADC chip and micro, but it appears to be unnecessarily complicated and time consuming.
Any ideas?
Thank you.
Any ideas?
Thank you.
