Thanks AtomSoft,
There never seems to be a standard for the cap rating unit, and I always used to get frustrated when I couldn't work out what nF, pF or uF were in other units!
I do it the lazy way now, my calculator has the units on it so I can just press a button to convert![]()
But rarely do you need to, usually an R suffices. In fact a C can screw things up. If it's too large the pin may rise too slowly to properly latch a rising edge and the part may not start or respond to ICSP/ICD. On the other hand, the minimum is zero, so... go with zero unless you have a known reason to do otherwise.Yes, you can make an external Power On Reset with a RC circuit connected to the MCLR.
