Define.. want to understand
Ayne
Can we define a constant to our SFR like below???
supose i define a constant x = PORTB,3 like below
#define   x     PORTB,3
if i change the the value of x then the whole PORTB will effected or just bit 3 of PORTB will be effected??
movlw   b'10110110'
movwf   x
what will be the result ???
PORTB = 10110110
OR
PORTB.3 = 0
In your case, occurance of "x" will be replaced by "PORTB,3" before the source file is processed by assembler or compiler.
If you change the #define to other things, "x" will be substituted by other thing too.
You code does not make sense.
movlw   b'10110110'
movwf   x                ;<<<< wrong !!!
because it substituted into "movwf PORTB,3" and movwf moves 8-bit at a time.
Your remaining questions have nothing to do with the above ASCII replacement.
Essentially all define and equate do is a simple text substitution during assembly, as do those in the inc file. In your example, because it makes no sense, the assembler will generate an error.
