I've tried the delay generator from piclist and I can't seem to get it working. It compiles without errors but the delay doesn't seem to work:
If however I use the following delay code from Nigels blinking lights tutorial it works fine:
LIST p=16F628 ;tell assembler what chip we are using
#include <p16F628.inc>
__CONFIG _CP_OFF & _WDT_OFF & _PWRTE_ON & _INTRC_OSC_NOCLKOUT & _LVP_OFF & _BODEN_ON & _MCLRE_OFF
org 0x0000 ;org sets the origin, 0x0000 for the 16F628,
;this is where the program starts running
movlw 7
movwf CMCON
clrf PORTA
clrw
tris PORTA ; porta all output
clrf PORTB
movlw 0xf0
tris PORTB
bsf STATUS, RP0 ; bank 1
bcf OPTION_REG, NOT_RBPU ;internal pullups on port B enabled
bcf STATUS, RP0 ;bank 0
Loop
movlw 0xff
movwf PORTA ;set all bits on
movwf PORTB
call Delay
movlw 0x00
movwf PORTB
call Delay
goto Loop
Delay
; Delay = 2 seconds
; Clock frequency = 4 MHz
; Actual delay = 2 seconds = 2000000 cycles
; Error = 0 %
cblock
d1
d2
d3
endc
;1999996 cycles
movlw 0x11
movwf d1
movlw 0x5D
movwf d2
movlw 0x05
movwf d3
Delay_0
decfsz d1, f
goto $+2
decfsz d2, f
goto $+2
decfsz d3, f
goto Delay_0
;4 cycles (including call)
return
end
cblock 0x20 ;start of general purpose registers
count1 ;used in delay routine
counta ;used in delay routine
countb ;used in delay routine
endc
movlw 7
movwf CMCON
clrf PORTA
clrw
clrf PORTB
movlw 0xf0
tris PORTB
Loop
movlw 0xff
movwf PORTB
call Delay
call Delay
call Delay
call Delay
call Delay
call Delay
call Delay
call Delay ; end of 2 secs
movlw 0x00
movwf PORTB
call Delay
call Delay
call Delay
call Delay
call Delay
call Delay
call Delay
call Delay
goto Loop
Delay movlw d'250' ;delay 250 ms (4 MHz clock)
movwf count1
d1 movlw 0xC7
movwf counta
movlw 0x01
movwf countb
Delay_0
decfsz counta, f
goto $+2
decfsz countb, f
goto Delay_0
decfsz count1 ,f
goto d1
retlw 0x00
end
