Demultiplexing with holding values on all outputs
MacIntoshCZ
Active Member
I would like to set value by DAC, select output and then hold this value as reference on specific output until its changed.
I would like to use as low parts as possible. I know how to do it with op amp but it will be to much parts if i want more outputs...
Any ideas? Thanks
An analog multiplexer feeding a capacitor for each output, and the DAC continuously "refreshing" the output values so they do not decay?
A CD4051 (or two of them) should work as the multiplexer (or rather demultiplexer).
Ok seems simple thanks. I was aware of voltage drops in time at output.
