I'm trying to repair a denon avr-2106 that went into protection mode. I've downloaded a service manual (avr-2106/886 ver. 1) although it doesn't appear to be for exactly the same model as I have - it's for a USA/Canada model and I'm in the UK.
I've now replaced the blown 2SB/2SD pair (B1560/D2390) (named 2SB1647/2SD2560 in the manual I have?) and their emitter resistors (as per unclejed613 in https://www.electro-tech-online.com/threads/denon-receiver-is-fried.109126/).
However, one of the zener diodes is also blown (ZD102FR). The problem is that my service manual doesn't show the zener diode in the circuit diagram and I'm having trouble identifying the case style and voltage. It's a surface mount part with two pins with a pin sticking out at each end (not wrapped around the body) and the body length measured 1.57mm (exluding pins) by 1.14mm and 0.77mm high.
Would anybody be able to tell me what the case style is? It looks a bit like SOD323 but the pins are different. I can unsolder a good zener and test its voltage but if anyone repairs these any knows or has a service manual that shows the part then that would really helpful!
Thanks in advance.
Thanks in advance.
