DigiTan
I'm in need of advice on what type of MOSFET I should use to switch off current from two battery supplies.
Basically, I've got this plan for a 6V regulator. The regulator output feeds to the supply of a graphing calculator that would normally use AAA batteries. I want to augment the original batteries with a second bank of AA cells. I've done this by linking both battery groups in parallel through a Schottky barrier pair to prevent backward current from the strongest battery set.
Then I added a regulator/TVS so that a wall adapater can be used as a third source. This also runs in parallel with the batteries and uses the same Schottyky barrier.
To maximize battery life, I want to completely shut of current from both battery groups whenever the adapater source is present. I used a relay in my previous version, however the switching time caused transients that could reset the calculator under certain conditions.
I want to replace the relay entirely. I've heard of depletion-mode MOSFETs being compared to normally-open switches, and this is exactly the type of behavior I need.
My questions are: will a depletion MOSFET in series with Battery supply 1 and 2 provide the switching I want without the need for a negative voltage supply? And will it have a very low transconductance when it is supposed to allow current from the batteries? I'm thinking the MOSFETs would go in series with D3 and D4 on the diagram?
