This is in reference to my earlier LM2907 shift-light project, which utilized a seperate third wire to the negative ignition coil of the car (or the tachometer output) to get the pulses. After looking around, I find that there are commercial shift lights which do not use a 3rd tachometer wire; instead, the ignition pulses can be derived from the power lines, which is all they use. Hence this makes the device much more portable.
However, I have NO inkling how to retrieve and filter out this square wave pulse off the 12v lines.. does anybody have any experience with this? Assuming that the ignition simply carries it, what circutry will be needed to bandpass the pulses alone?
