Design an avr based power meter
mangezi
How do i go about this design. im confused ,i need a hint.
The meter must do the following
1. Measure input voltage, current and power for a test circuit.
2. Be a reliable, high-precision device
3. Be a low-power battery operated device
4.Provide a PC interface (details below)
o The connection must be via USB
o The GUI must provide a virtual instrument that resembles your meter (similar displays and
controls)
o The GUI must allow the user to specify an extended averaging period. This will allow him view the average power consumption over a specified long duration (eg. two minutes)
That's a pretty ambitious project. Sounds like it needs to be microprocessor based. Are you familiar with those?
At crutshow ,i am not familiar with the microprocessor but that what i will be using in this design .if you can help me on that, i will be very grateful. I want to use c programing
First you need to draw a block diagram of all the various functions to be performed and how the signals flow between them. Then you need to do a detailed design for what's in each block.
If you don't know microprocessors then you certainly need to learn about them. Do you know how to program in C?
