I have to make A Single phase induction Furnace Of 1KW ..
Question is that How to Calculate Current ,Voltage ,Capacitor ,inductor and Macthing Inductor , Pout
An induction furnace does not have a heating element. It uses a coil to induce large currents in the item to be heated which heats the item due to it's intrinsic resistance. Some stove tops use induction heating to directly heat the pan. The pan bottom must be of suitable material to properly heat from the induction currents.
Suggest you do a search for "induction furnace design". You should find some helpful information to help solve your problem.
i am Using 220V Single Phase Input Voltage....
Than it is Rectified and Filtered .....
i wanna Know that if I wanna Make 1KW Induction Furnace (1kg /h) , whats the Design Calculations ???
Like what is the Output Voltage and Current At Half bridge Inverter output ?
and how to Calculate the Matching transformer specification ?? Since I want to reduce Voltage and Increase curent ....
And
Resistance Of Load ??
here is the Inverter Diagram I am Using IRFP450
but problem is that i am not Geting The 220V AC at Inveretr output ???**broken link removed**
the Operating Frequency Of Inveretr Is 3Khz
I am Using IRFP450
I am Using IRFP450
