FriedCircuitBoard
Hi everyone.
I am trying to take a battery charger that's powered by a 12v car plug (It is outputting 8.4v at 600mAh..):
Charger For Panasonic VW-VBG070 TM700 HS300 Camera+Car | eBay
..and connect a 12v solar panel to it as a source of power (that puts out 1.5watts):
12V(1.5 -110 W )Watt Solar Panel for Grid Tie Inverter - eBay (item 200543251172 end time Aug-10-11 21:25:53 PDT)
Would this every work?? Or is the panel too weak for such a system?
Watts = V x Amp
So i guess if you have, 1.5W - 12 x Amp, Amp = 1.5/12, So Amp = .125
So the panel puts out 125mAh. If we hook it up to that charger that needs to put out at least 600, what happens?
Does the battery still get charged at a slower rate, or does the charger not work at all?
Thanks so much for all your info and input!
I appreciate it..
Watts = V x Amp
I appreciate it..
