frasierdog
Imagine a bi-folding portable solar charger the size of a small novel. It collects solar energy by day and stores it in a high capacity internal battery. At night you can access your energy via a high powered 5V 2.5A USB port, enough to power any tablet or smart phone!
This week I am going to order the parts to assemble the first prototype of my DIY solar charger. I am pretty new to the DIY world. The basic design has already been created, but I am not totally sure which circuits and components I will need to make my project function the way I want it to. I suppose it's easiest to describe what I want it to do and work backwards from there. Below are some pictures I have done in Sketchup and Google Draw to give a rough idea of what this thing will look like!
Don't laugh! It was my first time using Sketchup!![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Functions: - ultimately I would like it to...
- Charge any USB device
- Support power draw up to 2.5 A
- Have a single button and 4 LEDs to indicate charge level and charging status
- Be able to power directly from the Sun, and fall back on stored energy only if the solar voltage isn't enough
Components - to achieve the above end, what pieces will I need?
- 2x high power solar panels (probably monocrystalline)
- 8000 mAh battery capacity
- Voltage controller for solar panels
- MPPT tracker
- USB Port (in and out)
- LED light piece
Well that is the basic idea. Yes, I know, it's far from electrically complete. That's why I have shared this idea with electro-tech. Perhaps you can help me fill the gaps in my knowledge (more like canyons)
Questions: - this is what I know I don't know, but does not include what I don't know that I don't know!
- Can a USB port support a 2.5A output?
- What kind of voltage booster would I need from the battery to the USB port?
- I would like to shoot for a sum total of 6000-8000 mAh of battery storage. Is it more efficient to do this with one large battery or two smaller ones? Is there a voltage advantage to wiring two smaller batteries in parallel?
- How do I build in a mini-usb in for 5V wall charging?
- What kind of circuit do I need for a charging status/capacity indicator?
- What kind of solar voltage controller can manage two solar panels? Do you wire them in parallel and then attach a voltage controller or is there a model that can accept two inputs simultaneously?
- What type of battery do I want to use? It must withstand prolonged charging and many hours spent outside basking in the sun.
- I would like the folded unit to be about the size of an iPad mini (5.3"x8"). With two solar panels approximately that size, is it possible to draw enough power to charge the battery fairly quickly?
I know it's a lot to digest! Thanks electro-tech! If anyone could point me in the direction of the right components it would be much appreciated - can't wait to build it and take a dream into reality!
- frasierdog
- MPPT tracker
- LED light piece
- frasierdog
