Development of an internet controlled surveillance mobile robot
suein
hai....
i need help here in JAVA programming. i already finish in robot development and the robot already can moving using mode that already program in the microcontroller build in the robot but now i need to do the JAVA interface to make the robot can be control using that mouse click . I'm using the skxbee as the interface between the robot and the pc. skxbee act like the wireless and use the usb port to connect at the pc.
if there are any code that can help me.
this is the objective for this project but if cannot via the internet also ok for this time.
 Develop the communication software so that the robot can be remotely controlled from the Internet
 Develop the streaming software so that the captured video can be streamed to the user using the Internet
t.
For your information,I'm using PR23 that i buy from cytron.I also buy starter kit XBEE PRO to communicate between PC and the robot.So i have invent VB window application to replace X-CTU. When we use the VB code , the communication between the skxbee worked well .But when i try to control the robot by sending number 8(forward) to PR23 robot its cannot detect.
The coding for the robot
void wireless_xbee (void)
lcd_clr(); // clear the lcd
while(1) // looping forever
lcd_goto (0);
if (data[0] == 100) // check if UART start byte is met
send_string(" XBEE CONTROL "); // display string
SPEEDL = 200; // set the motor speed
SPEEDR = 200;
while(1)
lcd_goto(20);
if (RCREG == '8') // if character '8' is detected, the robot move forward
forward();
send_string("FORWARD ");
else if (RCREG == '2') // if character '2' is detected, the robot move backward
backward();
send_string("BACKWARD ");
else if (RCREG == '6') // if character '6' is detected, the robot turn right
right();
send_string("TURN RIGHT ");
else if (RCREG == '4') // if character '4' is detected, the robot turn left
left();
send_string("TURN LEFT ");
else if (RCREG == '5') // if character '5' is detected, then stop the robot
stop();
send_string("INVALID COMMAND ");
else // else then stop the robot
stop();
else send_string("COMMAND");
Coding for the VB
' DO NOT FORGET: ADD A REFERENCE TO THE ACTIVECOMPORT LIBRARY FROM THE PROJECT->REFERENCE MENU
Public lTimerID As Long
Public objComport As ACOMPORTLib.ComPort
Private Sub buttonSubmit_Click()
textReceived = "--->"
objComport.WriteString (textSend)
GetResult
End Sub
Private Sub buttonView_Click()
If FileExists(textLogfile.Text) = True Then
Shell "notepad " + textLogfile.Text, vbNormalFocus
End If
End Sub
Private Sub CheckDTR_Click()
objComport.RaiseDTR (CheckDTR.Value)
GetResult
End Sub
Private Sub CheckRTS_Click()
objComport.RaiseRTS (CheckRTS.Value)
GetResult
End Sub
Public Function FileExists(sFileName As String) As Boolean
FileExists = CBool(Len(Dir$(sFileName))) And CBool(Len(sFileName))
End Function
Private Sub Form_Load()
textSend = "Text"
Set objComport = CreateObject("ActiveXperts.ComPort")
objComport.ComTimeout = 100
For i = 0 To objComport.GetDeviceCount() - 1
comboDevice.AddItem (objComport.GetDevice(i))
Next
comboDevice.AddItem "COM1"
comboDevice.AddItem "COM2"
comboDevice.AddItem "COM3"
comboDevice.AddItem "COM4"
comboDevice.AddItem "COM5"
comboDevice.AddItem "COM6"
comboDevice.AddItem "COM7"
comboDevice.AddItem "COM8"
comboDevice.ListIndex = 0
comboSpeed.AddItem "Default"
comboSpeed.AddItem "110"
comboSpeed.AddItem "300"
comboSpeed.AddItem "600"
comboSpeed.AddItem "1200"
comboSpeed.AddItem "2400"
comboSpeed.AddItem "4800"
comboSpeed.AddItem "9600"
comboSpeed.AddItem "14400"
comboSpeed.AddItem "19200"
comboSpeed.AddItem "38400"
comboSpeed.AddItem "57600"
comboSpeed.AddItem "64000"
comboSpeed.AddItem "115200"
comboSpeed.AddItem "128000"
comboSpeed.AddItem "256000"
comboSpeed.ListIndex = 0
comboHWFlowControl.AddItem "Default"
comboHWFlowControl.AddItem "Disable"
comboHWFlowControl.AddItem "Enable"
comboHWFlowControl.ListIndex = 0
comboSWFlowControl.AddItem "Default"
comboSWFlowControl.AddItem "Disable"
comboSWFlowControl.AddItem "Enable"
comboSWFlowControl.ListIndex = 0
comboDataFormat.AddItem "Default"
comboDataFormat.AddItem "8,n,1"
comboDataFormat.AddItem "7,e,1"
comboDataFormat.ListIndex = 0
textReceived = ""
EnableControls
End Sub
Private Sub buttonOPEN_Click()
objComport.Device = comboDevice.List(comboDevice.ListIndex)
If (comboSpeed.Text = "Default") Then
objComport.BaudRate = 0
Else
objComport.BaudRate = comboSpeed.Text
End If
objComport.LogFile = textLogfile.Text
objComport.HardwareFlowControl = comboHWFlowControl.ListIndex
objComport.SoftwareFlowControl = comboSWFlowControl.ListIndex
If (comboDataFormat.ListIndex = 0) Then
objComport.DataBits = objComport.asDATABITS_DEFAULT
objComport.StopBits = objComport.asSTOPBITS_DEFAULT
objComport.Parity = objComport.asPARITY_DEFAULT
End If
If (comboDataFormat.ListIndex = 1) Then
objComport.DataBits = objComport.asDATABITS_8
objComport.StopBits = objComport.asSTOPBITS_1
objComport.Parity = objComport.asPARITY_NONE
End If
If (comboDataFormat.ListIndex = 2) Then
objComport.DataBits = objComport.asDATABITS_7
objComport.Parity = objComport.asPARITY_EVEN
End If
objComport.Open
GetResult
EnableControls
End Sub
Private Sub buttonClose_Click()
objComport.Close
GetResult
EnableControls
End Sub
Private Sub Form_Unload(Cancel As Integer)
Timer1.Enabled = False
End Sub
Private Sub EnableControls()
Dim bOpened
bOpened = objComport.IsOpened
CheckDTR.Enabled = bOpened
CheckRTS.Enabled = bOpened
checkCTS.Enabled = bOpened
checkDCD.Enabled = bOpened
checkRI.Enabled = bOpened
checkDSR.Enabled = bOpened
buttonOpen.Enabled = bOpened + 1
buttonClose.Enabled = bOpened
buttonSubmit.Enabled = bOpened
Timer1.Enabled = bOpened
End Sub
Private Sub Timer1_Timer()
Dim strString
strString = objComport.ReadString
If (strString <> "") Then
textReceived = textReceived & strString & vbCrLf
End If
checkDCD.Value = Abs(objComport.QueryDCD)
checkCTS.Value = Abs(objComport.QueryCTS)
checkDSR.Value = Abs(objComport.QueryDSR)
checkRI.Value = Abs(objComport.QueryRI)
End Sub
Private Sub GetResult()
If objComport.LastError = 0 Then
textResult.Caption = "SUCCESS"
Else
textResult.Caption = "ERROR " & objComport.LastError & " ( " & objComport.GetErrorDescription(objComport.LastError) & " )"
End If
End Sub
