Can anyone put us straight please
I know the old series wound DC generators in cars would act as both.
The International Cub Cadet garden tractor of the mid-1960s used a full-size Delco automotive DC generator for its intended purpose and then switched the circuitry around to use it as a starter motor for the 7hp Kohler engine. The front of the engine had a pulley of about 10-inch diameter to provide better starting torque against the engine compression and a higher RPM rate for the generator when the engine was running. It was a very trouble-free system.
You are correct, of course. I was thinking of the starter windings.They were parallel wound. The field current was controlled by the regulator to keep the output voltage correct.
Crankshaft: Dynamos
