Difference between LM139 VS LM339 comparator IC chips
What's the Difference between LM139 VS LM339 comparator IC chips
LM139 uses PNP transistors?
LM339 uses NPN transistors?
Any other differences between the Two?
Both types use a mix of PNP and NPN transistors in their construction. According to the Texas Instruments data sheet (found here), the LM139/139A is characterized for use over the full military temperature range of -55C to +125C, while the LM339/339A is characterized for use between 0C and +70C.
(beat me by just a couple minutes, ronv)
Nope.
Some of the specifications are sensitive to temperature so all it does is guarantee the specifications over a broader range of temperature.
Check out the data sheet.
There in pairs....
Allthough self heating through dissipation does come into it, the temp rating is more for the ambient temp.
A military device may be expected to work in artic extreme cold and in a hot desert so needs a wider temp range, automotive use also demands a wide range, your tv however probably wouldnt be used at -55 degrees.
