sachin.kolkar
hi guys,
i m facing problem with timer
sachin.kolkar said:hi guys,
i m sending my codePommie said:Unbelievable.
unsigned short counter,second,m;
void main()
TRISB=0x00;
PORTB=0x0F;
T1CON=0b00001001;
TMR1H=0x80;
TMR1L=0x0F;
T1CON.TMR1ON=1;
PIR1.TMR1IF=0;
PIE1.TMR1IE=1;
INTCON=0xC0;
d0
if(counter==30)
counter=0;
second++;
if(second==60)
m++;
second=0;
if(m==1)
m=0;
PORTB=~PORTB;
}while(1);
void interrupt()
counter++;
TMR1H=0x80;
TMR1L=0x04;
PIR1.TMR1IF=0;
do you mean that making TMR1L=0x00; TMR1H=0x00; is initializing the counter right ..........Pommie said:That is because you don't initialise counter or seconds in your code. Try setting them to zero at the start of your main routine.
Pommie said:Just set them to zero,
Code:unsigned short counter,second,m; void main() { [COLOR="Blue"] counter=0; second=0;[/COLOR] TRISB=0x00; PORTB=0x0F; T1CON=0b00001001; TMR1H=0x80;
You might also consider setting m=0 as well.
