amady said:Actually i'm try to setup the PIC kit like nigel's site.. when i'm trying to change the programming (.asm)... it has an error... so which one 'WORD' is not same between 16F628 and 16F84A??? so i can modified the programming...
what was the error ?it has an error...
williB said:what was the error ?it has an error...
amady said:williB said:what was the error ?it has an error...
I think i was solve the error... the error is can't recognize command CMCON....
Those are the two lines you have to remove, the 16F628 has internal comparators which are turned ON by default - those two lines (writing to CMCON) turn the comparators OFF, making it look like a 16F84.
i run MPLAB it come the error:
source file path exceeds 62 characters
amady said:i run MPLAB it come the error:
What the problem??
Nigel: but I never use MPLAB, so I can't be sure
amady said:Nigel: but I never use MPLAB, so I can't be sure
So can i know what asembler was you used?? It's free??? :lol:
Nigel Goodwin said:Yes it's free, it's called MPASM and is installed along with MPLAB - you may need to look in the MPLAB directory for it - it's MPASMWIN.EXE.
amady said:Thanks nigel, i was solve my problem.. the 'atferrari' was give some tip.. I was download your zip file for .asm and also the hardware. But the stepper motor tutorial is not there :!: ... TQ :lol:
No, I haven't written it yet - so much to do, so little time
