Digital Lamp Dimmer
sahu
i want to make Digital Lamp Dimmer with nec ir remote using 16f676 & compailer used HI-TECH Software\PICC\PRO\9.60. those code are as
// Global includes
#include <htc.h>
__CONFIG(FOSC_INTRCIO & WDTE_OFF & PWRTE_OFF & MCLRE_OFF & CP_ON & CPD_OFF);
#define IRSENSOR RA3 //IR LED input with R10K pull-up to vcc
#define fan_1 RA1     // Drive output 1{pin.11}
#define fan_2 RA2     //Drive output 2{pin.10}
#define Zero_cros  RC1 //
#define Buzzer  RC0 //
#define LED RA0 // Speaker // IR port status indicator LED defination
//#define TICKSPERMS 1004 // tick in a milli second
#define TICKS11ms 11044 // ticks in 11ms
#define TICKS5o5ms 5522 // ticks in 5.5ms
#define TICKS2o3ms 2309 // ticks in 2.3ms
#define TICKS3ms 3012 // ticks in 3sm
#define TICKS0o2ms 200 // ticks in 0.2ms
#define TICKS8ms 8032 // Tick in 8ms
unsigned int TIMEOUT = TICKS11ms; // the pulse should occur before this time excede Otherwise it is an error
unsigned int PREPULSE = TICKS8ms; // the interrupt should occur after this time Otherwise it is an error
static unsigned short long timer; // varible to keep track of long timeouts ( it can also be int if you want to save flash memory for some other purpose )
static unsigned char dataready; // varible to use as flag when data is completly received and ready it is 1 else 0
static unsigned char necpoj=0; /* (necpoj=NEC position )this varible is used to keep track of the edges of the input singal
as decoding of the singal is done by a state machineso this varible acutalley sotores what state we
currently are and total bits 32 and 2 leading pulse */
static unsigned char address=0,notaddress=0; // these varible are used to store received address
static unsigned char command=0,notcommand=0; // these varible are used to store received address
// global variables
unsigned int current=5;
unsigned int ch_cnt=0;
void interrupt(void);// zero crossing sence here
void interruptOnChangeIsr(void); // interrupt service routine for interrupt on change of input port for IR sensor of mcu
void timerInterruptIsr(void); // interrupt service rouine for timer0
void delayMs(int x);
void interrupt t0intr(void)
    if(INTCONbits.T0IF)                            // check the timer0 over flow interrupt flag
    timerInterruptIsr();                        // timer0 overflow interrupt has been occur call the isr
    INTCONbits.T0IF =0;                            // clear the timer0 interrupt flag
    else if (INTCONbits.RAIF)                    // check the interrupt on change flag
        LED=1;                                    // to blink the LED when IR signal is received
        interruptOnChangeIsr();                    // interrupt on change has been detected call the isr
        INTCONbits.RAIF =0;                        // clear the interrupt on chage flag
        LED=0;                                    // to blink the LED when IR signal is received
/* THE main source code Start here*/
void main()
    CMCON=0x7; // disable the comparator
    ANSEL=0x00; // all pin are Digital
    TRISA=0x10;
    TRISC=0x00;
    PORTA=0x10; // Only RA4 is set to input rest are out
    PORTC=0x00; // Only RA4 is set to input rest are out
        TMR0 = 0; // clar the timer
        OPTION_REG = 0x88; //pullups are disabled
                                                        //timer0 clock source is internal
                                                        //timer0 perscaller is 1:1 (disabled "assigned to WDT")
         IOC = 0x8; //interrupt on change is only to the RA3
         INTCONbits.T0IE = 1; // Timer0 overflow interrupt enable
         INTCONbits.T0IF = 0; // clar the timer0 intrrupt flags
         INTCONbits.RAIE = 1; // external interrupt on GPIO3 pin(4) is enabled
         INTCONbits.RAIF = 0; // clear the external interrrupt flag
         INTCONbits.PEIE = 1; // peripheral intrrupt enable
         INTCONbits.GIE = 1; // GLOBL interrupt enable
        EEADR = 0x00; // load the state of port from EEPROM
        EECON1bits.RD = 1; // Start reding EEPORM
        PORTA = EEDATA; // LOAD The readed data form EEPORM to PORTA
        PORTC = EEDATA; // LOAD The readed data form EEPORM to PORTC
        while(1) // wait forever for the data received and ready
        if(dataready) // data is received and ready to be procssed
                //// key resver --      0x40
                //// key resver ++      0xC0
                //// key vol --      0xA0
                //// key vol ++      0x60
         switch(command) //
            // key resver --      0x40 FAN_1 SPEED Minus_Button
         while(!case 0x40)
         if(current<90)
          current+=10;
          Delay_ms(20);
         else
          current = 100;
         LED = 1;
         Delay_ms(80);
         Buzzer = 0;
         time_delay = 0;
         break;
            // key resver ++      0xC0 FAN_1 SPEED Plus_Button
        while(!case 0xC0)
          if(current>11)
            current-=10;
            Delay_ms(20);
          else
           current = 0;
          Buzzer = 1;
          Delay_ms(80);
          Buzzer = 0;
          time_delay = 0;
         break;
                    default :
                        break;
                EEADR = 0x00; //Write PORT status to EEPROM
                EEDATA = PORTA; // load the current status of GPIO to EEPROM write register
                EEDATA = PORTC;
                 EECON1bits.WREN = 1; // Enable EEPROM write
                 INTCONbits.GIE = 0; //1 disable the interrupts as it may currupt the EEPROM data
                EECON2 = 0x55; //2
                EECON2 = 0xAA; //3 (1,2,3) require sequence
                 EECON1bits.WR = 1; // satart writing
                 INTCONbits.GIE = 1; // Enable the interrupts
                dataready=0; // data has been processed so clear the dataready flag
unsigned short long tdiff;
unsigned char pin;
static unsigned long rxbuffer;
tdiff = ((timer<<8)+TMR0) ; // calculate how much time has been passed since last interrupt
        // the time shold be less then time out and greater than PREPULSE
pin = IRSENSOR; // store the current status of Sensor
TMR0 = 0; // reset the timer0 to measure the next edge(interrupt) of input
timer = 0; // reset the timer varible to
/* state machine is started here and it totally managed and keeps track of its states using the varible necpoj
here are the details of necpoj ( NEC position ) varible
if
necpoj == 1 we just detected the first edge of the input singal it may also mean(if interrupt is not false) that the 9ms leading pulse started
                                  after the first edge THE next pulse is expected to arrive around 9ms so the TIMEOUT is set to 11ms and PREPULSE is set to 8ms
necpoj == 2 we just detected the second edge of the input signal and we finished the 9ms leding pulse and now 4.5ms space started
                                  after the second edge the next pulse is expected to arrive around 4.5ms so TIMEOUT is set to 5.5ms and PREPULSE is 3ms
necpoj == 3 we just detected the third edge of the input singal and we finished 4.5ms space and addres lsb is now started
                                  after the third edge the next pulse is expected to arrive around 562.5us so TIMEOUT is set to 2.3ms and PREPULSE is 0.2ms (timeout can be much less at this state but to do this i have to add one more if else statemetnt)
necpoj == 4 we just decected the forth edge and the 562.5 us burt of LSB of address has ended now a little space for '0'562.5us or for '1' 1.6875ms
                                  after the forth edge the next pulse is expected to arrive for '0' around 562.5us and for '1' 1.675ms so TIMEOUT is set to 2.3ms and PREPULSE is 0.2ms
necpoj ==5 to 66 data pulse keep comming
                                        TIMOUT and PREPLUSE remain same as above.
necpoj ==67 we just fined the command inverse MSB space not the final 562.5us burst has stated so we fined the receiveing
                                  now we will check the address and command for being correct
if ((tdiff>PREPULSE) && (tdiff<TIMEOUT) ) // the edge (interrupt) occurrence time should be less then the TIMOUT and greater then PREPULESE else it is an fake singal
{ // At the very first edge (necpoj==0) this conditon will always false and the false block of this if will bring the state machine (necpoj) to position 1(position 1 means 9ms leading pulse has started now we have to wait for 4.5ms start pulse to occur)
        if(necpoj==1 || necpoj==2) // when we are hear it means 9ms leding pulse has ended and now we are necpoj=1 or necpoj=2
                        if((pin==1) && (necpoj==1))
                        necpoj++;
                        TIMEOUT = TICKS5o5ms; // timeout for 3rd pulse 5.5ms
                        PREPULSE = TICKS3ms; // PREPULSE for 3rd pulse 3ms
                        else if((pin==0)&& (necpoj ==2))
                        necpoj++;
                        TIMEOUT = TICKS2o3ms; // now data starts so timeout is 2.3ms
                        PREPULSE = TICKS0o2ms;
                        else // this block handle the conditon if any error occur after the completing the pre pulses
                        necpoj = 0; //reset the state machine
        else if(necpoj>2) //now we are picking the data
        {  necpoj++; //necpoj sill inrement on every edge
             if(necpoj&0x01) // here we check the if necpoj is an odd number because when necpoj goes greater then 3 then
  //necpoj will always be and odd value when a single bit tranmission is over
             { rxbuffer=rxbuffer<<1; //shift the buffer
                 if(tdiff>1250) //we are here means we just recevied the edge of finished tranmission of a bit
  // so if last edge was more than 1.24 ms then the bit which is just over is one else it is zero
                { rxbuffer = rxbuffer | 0x1;
                  // GPIObits.GPIO5 = !GPIObits.GPIO5;
                      else{rxbuffer = rxbuffer |0x0;
                            // GPIObits.GPIO4 = !GPIObits.GPIO4;
                        if(necpoj >66) // we have reached (Leading pulse 2 +address 16+~address16+ command 16+ ~command 16+ last final burst first edge 1)=67th edge of the message frame means the date tranmission is now over
                        address = (rxbuffer>>24)& 0xFF; //extract the data from the buffer
                        notaddress = (rxbuffer>>16)& 0xFF;
                        command = (rxbuffer>>8) & 0xFF;
                        notcommand = (rxbuffer) & 0xFF;
                        rxbuffer=0; //clear the buffer
                                        if((!(address & notaddress)) && (!(command & notcommand))) // check weather the received data is vaild or not
                                    //    if((address =0x01)&& (!(command & notcommand)) ) //NOT WORK
                        //    if((!((address ==0x01) && (notaddress)) && (!(command & notcommand)))
                                        dataready =1;
                                        else
                                        dataready=0;
                        TIMEOUT = TICKS11ms; // weather we received the vaild data or not we have to reset the state machine
                        necpoj=0;
        else
        {        TIMEOUT = TICKS11ms; // some error occured reset state machine
else
{ if(pin==0) //we are here means that after a longtimeout or PREPULSE we just detect a pulse which may be the start of 9ms pulse
        necpoj = 1; // yes it could be the start of 9ms pulse
        else
        necpoj = 0; // no it's not start of 9ms pulse
        address = 0xFF;
        notaddress = 0xFF;
        command = 0xFF;
        notcommand = 0xFF;
        dataready = 0x000;
        TIMEOUT = TICKS11ms; //default timing
if(timer<0xFFFF) // this code is to increment the variable timer's value on every over flow but this if conditon will prevent this variable form rollover when a long timeout occurs
timer++;
void delayMs(int x)
int i;
for (x ;x>0;x--)
for (i=0;i<=110;i++);
void interrupt()
     while(Zero==0)
       ch_cnt++;
       while(ch_cnt<=105-current)
        fan_1 = 0;
        break;
       while(ch_cnt>=105-current)
        fan_1 = 1;
        break;
       break;
     while(Zero==1)
       fan_1 = 0;
       ch_cnt = 0;
       break;
    // Timer settings
    TMR0IF_bit = 0;
    TMR0 = 250;
}// interrupt
but when i compiled it found error as
Error [499] ; 0. undefined symbol:
_main(startup.obj)
********** Build failed! **********
i know tmr0 used in nec protocall .any body guied me for zero crossing detecting with tmr1 ?
