Fahime said:what do u mean of walmart?
The websites included Ding-dong kits and they were just for sale. There were no information about the IC, its name or datasheet. I need name or datasheet of some Ding dong ICs.Papabravo said:If you ever want us to respond to your requests again you should be able to justify your response that those circuits were not helpful. In the process it will help you refine your requirements, which are vague to say the least. The lack of suitability of the responses is directly related to your vague requirements. How can we help you if you won't even help yourself.
Two of the circuits that I saw identified the IC's being used. The 555 is a very common part. The datasheets can be found by using any search engine and entering:Fahime said:...There were no information about the IC, its name or datasheet. I need name or datasheet of some Ding dong ICs....
Fahime said:I'm looking for a high quality sound Ding dong IC for door bell. DO you know some? I have BT8031-2s but I don't like the voice.![]()
Fahime said:thanks for your help but none of these websites are helpful.
This kind of IC should be expensive. The cost is the main factor.Hero999 said:You could record the sound on a sound IC and connect the 'play' pin to the push button switch on the door.
What do you think about the voice? Do u think that it is acceptable? I mean for a doorbell.vedo35 said:we were using sab0600
[/url]
