Dr.EM said:Hmm, never knew that. so, how would you stop the current flow? By switching it off, presumably at the current source, then the SCR is reset and non-concucting once more?
Dr.EM said:Cool, that clears that up very nicely
I have an SCR, thought it'd be a useful part to have available, only a TO-92 one though.
Nigel Goodwin said:Dr.EM said:Cool, that clears that up very nicely
Hears a picture of the one I have :lol:
For scale, it's on a sheet of A4 paper, and that's my tea mug next to it!.
Optikon said:Nigel Goodwin said:Dr.EM said:Cool, that clears that up very nicely
I once saw one as big as your mug!
Someone Electro said:WOW! :shock:
That thing is huge.How much curent can it pass?
dar2525 said:Dr.EM said:Hmm, never knew that. so, how would you stop the current flow? By switching it off, presumably at the current source, then the SCR is reset and non-concucting once more?
Once the SCR is conducting, high current in must cases, the only way it goes into nonconducting mode is if the current conducting through the SCR falls below the holding current. The holding current is on the spec sheet, about 8mA. Once the current that passes through the SCR falls below 8mA the SCR stops conducting. It conducts again by triggering the gate.
Styx said:...after a while there was a build up of carbon dust that would every now and again fall and cause a nice beeg arch between thyrstor stacks...
