team dougherty
Hello, I have looked all over the internet for a way to disable the DRLs, Daytime Running Lights, on my car. There are solutions out there but they also disable another feature that I like. The car does have a way to disable them but it must be done every time the car is started. a real pain. I know what I would like to do to disable them automatically but I am not an electronics expert by any degree.
In my search for a solution, I was looking how to use a 555 timer, way over my head, I found this site. I looked around and found some great posts and a lot of smart people. Hopefully someone here can design and build the circuit for me.
Here is what I would like.
The DRLs can be disabled by pushing the dome over ride button four times within 6 seconds after the car is started. This has to be done every time the car is started.
After some investigation I found out the the dome over ride switch is a double action switch. Push for on and push for off. all the switch does in take an output from the BCM, Body Control Module, and sends it to ground.
The output from the BCM is 12 volts and when grounded 12.25 ma of current flows. The picture below shows two needles in the plug. one is the wire that goes to ground the other from the BCM. they both go to the dome over ride switch when plugged back into the switch housing.
when those two pins are connected and disconnected twice I get the familiar beep beep from the car that the DRLs have been disabled.
So, I will need a circuit that will sense when the car is started, there a several wires that I can tap into that are only hot when the car is running, and wait a half second, close a set of contacts for a half second, the open for a half second, then close for a half second then open and wait til the next time the car starts and then repeat the whole process.
This will give me exactly what I want. Can any one help me with this?
Thanks for taking the time to read.
Paul
Paul
