EJ Jurich
While troubleshooting a Harris 5KW AM transmitter problem, it became necessary to discharge the 10,000 volt filter cap. The problem was that as soon as the plate was turned on, the transmitter had an immediate overload shutdown. This was a 4CX5000 final vacuum tube rig with a 10,000 volt power supply. To trace the problem, I started disconnecting the high voltage supply back towards the power supply, each time trying to get the plate voltage on. Finally, I opened a point and the high voltage supply came on. I knew what the problem was. However, walking around to the back side of the transmitter, I heard a sizzling sound and I could smell ozone. I realized that when I opened the last supply point, I also removed the bleeder resistor from the supply. With no load, the cap was probably charged considerably more than 10,000 volts. I looked at the station manager and said "there is only one way to do this". Using the shorting rod, I tapped the capacitor terminal. The bang was incredibly loud.
Although I was a bit lax in not following the diagram enough to realize the bleeder would be removed from the circuit, Each time I opened a point, I used the shorting rod before opening the next point. In other words, I made sure the cap was discharged each time before putting my hands in. My senses cluing me in that the cap was charged did save me a fright. I knew what to expect when discharging the cap.
I've worked with voltages few people doing electronic work will ever need to deal with. The highest was a 50KW AM transmitter with a 40KW, 4amp DC supply. Putting your hands in a tube amp chassis can be equally dangerous. My father told me that while working on a radio chassis at home, he picked up the chassis while powered on and his hand caught the high voltage. The only way he could let go was to fling the radio out of his hands.
