Hi All
DO NOT TRY AT HOME
I have been pondering the idea of Grid Tie Inverts using discrete components but do not have the experience to correctly design it. I tried to get some comments from another forum but the thread was closed after a day citing it would void my insurance and is dangerous - sure, thats fine.
Any way I came up with the following circuit which I initially thought should be a constant voltage, I have not done my maths but would that be required even if it was hooked up in parallel?
The 3 phase AC is converted to DC
The DC is chopped and put through a step up transformer. The chopper also regulates the voltage from the output to maintain a constant voltage?
The transformer output is rectified back to DC
The DC is then converted to mains synchronized AC and injected into the grid. This part I found at on Grid tie Inverter but I don't think it would work as it would produce a more square wave.
I would prefer to use power fets rather than triacs as well.
Also working with mains AC is dangerous do not attempt to build this if you do not know what you are doing!
What are your thoughts folks?
Al
DO NOT TRY AT HOME
Al
