I have recently used nigel goodwins lcd tutorial to display a message on an lcd.
Now I would like to integrate a ds18s20 into my cicuit and display the outcome on the lcd display, but cant figure out howto do it.
I currently have this asm from nigel goodwin to display a message:
and found this code to retrieve the temp from the maxim website:
how can I combine the two so that I just add the ds18s20 into the current lcd project and display the temprature on it?
;LCD text demo - 4 bit mode
;Nigel Goodwin 2002
LIST p=16F628 ;tell assembler what chip we are using
include "P16F628.inc" ;include the defaults for the chip
ERRORLEVEL 0, -302 ;suppress bank selection messages
__config 0x3D18 ;sets the configuration settings (oscillator type etc.)
cblock 0x20 ;start of general purpose registers
count ;used in looping routines
count1 ;used in delay routine
counta ;used in delay routine
countb ;used in delay routine
tmp1 ;temporary storage
tmp2
templcd ;temp store for 4 bit mode
templcd2
endc
LCD_PORT Equ PORTA
LCD_TRIS Equ TRISA
LCD_RS Equ 0x04 ;LCD handshake lines
LCD_RW Equ 0x06
LCD_E Equ 0x07
org 0x0000
movlw 0x07
movwf CMCON ;turn comparators off (make it like a 16F84)
Initialise clrf count
clrf PORTA
clrf PORTB
SetPorts bsf STATUS, RP0 ;select bank 1
movlw 0x00 ;make all pins outputs
movwf LCD_TRIS
bcf STATUS, RP0 ;select bank 0
call Delay100 ;wait for LCD to settle
call LCD_Init ;setup LCD
clrf count ;set counter register to zero
Message movf count, w ;put counter value in W
call Text ;get a character from the text table
xorlw 0x00 ;is it a zero?
btfsc STATUS, Z
goto NextMessage
call LCD_Char
call Delay255
incf count, f
goto Message
NextMessage call LCD_Line2 ;move to 2nd row, first column
Message2 movf count, w ;put counter value in W
call Text2 ;get a character from the text table
btfsc STATUS, Z
goto EndMessage
call LCD_Char
incf count, f
goto Message2
EndMessage
Stop goto Stop ;endless loop
;Subroutines and text tables
;LCD routines
;Initialise LCD
LCD_Init movlw 0x20 ;Set 4 bit mode
call LCD_Cmd
movlw 0x28 ;Set display shift
call LCD_Cmd
movlw 0x06 ;Set display character mode
call LCD_Cmd
movlw 0x0d ;Set display on/off and cursor command
call LCD_Cmd
call LCD_Clr ;clear display
retlw 0x00
; command set routine
LCD_Cmd movwf templcd
swapf templcd, w ;send upper nibble
andlw 0x0f ;clear upper 4 bits of W
movwf LCD_PORT
bcf LCD_PORT, LCD_RS ;RS line to 0
call Pulse_e ;Pulse the E line high
movf templcd, w ;send lower nibble
movwf LCD_PORT
call Delay5
retlw 0x00
LCD_CharD addlw 0x30
LCD_Char movwf templcd
movwf LCD_PORT
bsf LCD_PORT, LCD_RS ;RS line to 1
movwf LCD_PORT
call Delay5
retlw 0x00
LCD_Line1 movlw 0x80 ;move to 1st row, first column
call LCD_Cmd
retlw 0x00
LCD_Line2 movlw 0xc0 ;move to 2nd row, first column
call LCD_Cmd
retlw 0x00
LCD_Line1W addlw 0x80 ;move to 1st row, column W
call LCD_Cmd
retlw 0x00
LCD_Line2W addlw 0xc0 ;move to 2nd row, column W
call LCD_Cmd
retlw 0x00
LCD_CurOn movlw 0x0d ;Set display on/off and cursor command
call LCD_Cmd
retlw 0x00
LCD_CurOff movlw 0x0c ;Set display on/off and cursor command
call LCD_Cmd
retlw 0x00
LCD_Clr movlw 0x01 ;Clear display
call LCD_Cmd
retlw 0x00
LCD_HEX movwf tmp1
swapf tmp1, w
andlw 0x0f
call HEX_Table
call LCD_Char
movf tmp1, w
andlw 0x0f
call HEX_Table
call LCD_Char
retlw 0x00
Delay255 movlw 0xff ;delay 255 mS
goto d0
Delay100 movlw d'100' ;delay 100mS
goto d0
Delay50 movlw d'50' ;delay 50mS
goto d0
Delay20 movlw d'20' ;delay 20mS
goto d0
Delay5 movlw 0x05 ;delay 5.000 ms (4 MHz clock)
d0 movwf count1
d1 movlw 0xC7 ;delay 1mS
movwf counta
movlw 0x01
movwf countb
Delay_0
decfsz counta, f
goto $+2
decfsz countb, f
goto Delay_0
decfsz count1 ,f
goto d1
retlw 0x00
Pulse_e bsf LCD_PORT, LCD_E
nop
bcf LCD_PORT, LCD_E
retlw 0x00
;end of LCD routines
HEX_Table ADDWF PCL , f
RETLW 0x30
RETLW 0x31
RETLW 0x32
RETLW 0x33
RETLW 0x34
RETLW 0x35
RETLW 0x36
RETLW 0x37
RETLW 0x38
RETLW 0x39
RETLW 0x41
RETLW 0x42
RETLW 0x43
RETLW 0x44
RETLW 0x45
RETLW 0x46
Text addwf PCL, f
retlw 'H'
retlw 'e'
retlw 'l'
retlw 'l'
retlw 'o'
retlw 0x00
Text2 ADDWF PCL, f
RETLW 'R'
RETLW 'e'
RETLW 'a'
RETLW 'd'
RETLW 'y'
RETLW '.'
RETLW '.'
RETLW '.'
RETLW 0x00
end
; Dallas Semiconductor PIC code
; This code will interface a PIC16F628 microcontroller to
; a DS2761 High-Precision Li+ Battery Monitor
; VCC
; \ Rpup
; 16F628 | DS2761
; RB1 (pin 7) ------------------------------ DQ (pin 7)
; List your processor here.
list p=16F628
; Include the processor header file here.
#include <p16F628.inc>
; Assign the PORTB with Constants
constant DQ=1 ; Use RB1 (pin7) for 1-Wire
; These constants are standard 1-Wire ROM commands
constant SRCHROM=0xF0
constant RDROM=0x33
constant MTCHROM=0x55
constant SKPROM=0xCC
; These constants are used throughout the code
cblock 0x20
IOBYTE
TMP0 ; Address 0x23
COUNT ; Keep track of bits
PICMSB ; Store the MSB
PICLSB ; Store the LSB
PDBYTE ; Presence Detect Pulse
endc
; Setup your configuration word by using __config.
; For the 16F628, the bits are:
; CP1,CP0,CP1,CP0,N/A, CPD, LVP, BODEN, MCLRE, FOSC2, PWRTE, WDTE, FOSC1, FOSC0
; CP1 and CP0 are the Code Protection bits
; CPD: is the Data Code Protection Bit
; LVP is the Low Voltage Programming Enable bit
; PWRTE is the power-up Timer enable bit
; WDTE is the Watchdog timer enable bit
; FOSC2, FOSC1 and FOSC0 are the oscillator selection bits.
; CP disabled, LVP disabled, BOD disabled, MCLR enabled, PWRT disabled, WDT disabled, INTRC I/O oscillator
; 11111100111000
__config 0x3F38
; Set the program origin for subsequent code.
org 0x00
GOTO SETUP
NOP
NOP
NOP
GOTO INTERRUPT ; PC 0x04...INTERRUPT VECTOR!
INTERRUPT:
SLEEP
; Option Register bits
; ____
; RBPU,INTEDG,TOCS,TOSE,PSA,PS2,PS1,PS0
; 7=PORTB Pullup Enable, 6=Interrupt Edge Select, 5=TMR0 Source,
; 4=TMR0 Source Edge, 3=Prescaler Assign, 2-0=Prescaler Rate Select
; 11010111
; PORTB pullups disabled,rising edge,internal,hightolow,TMR0,1:256
SETUP:
BCF STATUS,RP1
BSF STATUS,RP0 ; Select Bank 1 of data memory
MOVLW 0xD7
MOVWF OPTION_REG
BCF STATUS,RP0 ; Select Bank 0 of data memory
BCF INTCON,7 ; Disable all interrupts.
GOTO START
; Include the 1-Wire communication routines and macros
#INCLUDE 1w_16f6x.inc
START:
GET_TEMP:
CALL OW_RESET ; Send Reset Pulse and read for Presence Detect Pulse
BTFSS PDBYTE,0 ; 1 = Presence Detect Detected
GOTO NOPDPULSE
MOVLW SKPROM
CALL DSTXBYTE ; Send Skip ROM Command (0xCC)
MOVLW 0x69
CALL DSTXBYTE ; Send Read Data Command (0x69)
MOVLW 0x0E
CALL DSTXBYTE ; Send the DS2761 Current Register MSB address (0x0E)
CALL DSRXBYTE ; Read the DS2761 Current Register MSB
MOVF IOBYTE,W
MOVWF PICMSB ; Put the Current MSB into file PICMSB
CALL DSRXBYTE ; Read the DS2761 Current Register LSB
MOVF IOBYTE,W
MOVWF PICLSB ; Put the Current LSB into file PICLSB
CALL OW_RESET
NOPDPULSE: ; Add some error processing here!
SLEEP ; Put PIC to sleep
end
