Hi Everyone,
I am building a 10 LED display to replace the current meter of a 24v battery charger. The plastic case of the meter became deformed due to high contact resistance of the push-on terminals.
I have designed and built a display using TTL because LM3914 is not available and I want to make use of my TTL chips before they die of old age.
Briefly, IC1A clocks the 74160 counter and IC1B compares the staircase waveform produced by the R/2R d to a converter with the input signal. When the ramp exceeds the input signal, the transistor is turned off so the remaining leds do not light. High brightness leds are used because the duty cycle of each led is only 10% . The 7442 bcd to decimal decoder grounds the lower end of each led one at a time depending on the address from the 74160.
The circuit has the advantage that a multi channel display can be made by adding extra comparators, leds and transistors using the same staircase waveform.
The charger is rated at 20 Amps (30Amp max) and has a voltage control circuit consisting of a unijunction transistor based PWM circuit driving a thyristor. Line frequency is 50Hz.
Suitable shunt resistors are not available so I intend to use a suitable length of copper wire.
My questions are :
1. How would I tailor the response of the current shunt amplifier to match the response of the original moving iron meter.
2. Would temperature compensation be necessary due to the non zero resistive temperature coefficient of copper.
Thanks in advance,
Timescope.
![TTL based bar graph display.png TTL based bar graph display.png](https://www.electro-tech-online.com/data/attachments/52/52232-101c7937c2d27e19669b970c930a2b7f.jpg)
My questions are :
Thanks in advance,
Timescope.
