Oznog
Active Member
I have a solid state relay which says on the diagram "240V-480V". I need to use it to switch a 120v motor.
Now, if it had JUST said 480V, then I'd just take it as a maximum. But this implies that 240V is a recommended minimum, doesn't it? I mean if 480v is the maximum then you wouldn't bother to say 317v or 240v or 120v or 50v was also possible.
The seller did describe it as 24-480v. (24, not 240 as stated on the device). Most of what's written on the device is Chinese anyways, a typo would not be unheard of.
OK to use on 120v??
OK to use on 120v??
