Do you know if sync input works on LT1248 LTspice model?
Flyback
Please find a LTspice schematic of the LT1248 with a sync pulse attached...the sync pulse isnt working. Do you know why?
  • LT1248 PFC with Sync.asc
Check with Linear. It looks like their model ignores anything on the Enable pin, including using it to shut off the controller...
Agree. Clamping the EN pin to ground doesn't cause shut-down as it should.
Yes...If you right click on the part, it states "External Sync capability is not modeled". I guess it should state "ena/sync functionality is not modeled".
The SYNC function of any LTC device is not modelled in LTspice (especially dc/dc converters). If an LTspice model has a SYNC pin, then it is normally because that SYNC pin is shared with another function and LTspice is modelling that second function and not the SYNC function. Hope that makes sense.
The additional pullup to Vcc is probably because of the leakage current of the VN2222. This can be as high as 200uA, so with just a pull up to VREF, would cause an excessive voltage drop across the pull up resistor. If you lower the pull up resistor value, it would cause too much stress for the output capability of VREF when the FET is ON. The extra pull up path to Vcc overcomes this. The diode stops Vcc back feeding into VREF.
Thankyou SimonBramble, is there actually a current source in the PKlim pin chucking out 50uA?....The block diagram doesn.t show a current source there.
It is probably just horrific bias current coming out of the base of a pnp transistor. The bias currents into and out of the other pins is quite high. This part was released back in 1993 so bias currents (especially on a bipolar process) were much higher back then
