savvej
I have a extension board and it has a 3 pin socket and a switch associated with it.
Its connections are as shown in diagram attached :
Now when I switch "on" the switch,the led/lamp (am not sure) inside glows inside it.
Now when I take the tester and put it in the L hole--it lights up as expected.
But when I put it in the neutral plug ,the tester does'nt light up.
Now according to the diagram which I have shown,I should be getting voltage on neutral too because it is connected via led and resistor to the neutral.And thus tester should have lit ...why is it not happening so?
Note that this case is different from just having a plug and a switch with no lamp associated with it..
PS. added photo of tester(just in case if you call it differently)
