I am doing a project " Infant monitoring system using PIC16F877A". It uses 3 sensors LM35 temperature sensor, CO2 sensor and breath rate sensor. We are transmitting those signals through RS-232 to PC for displaying in VB application. I am new to the VB sessions.
I want to know these :
1. When transmitting the data to the PC through RS-232 cables, where will the data be stored?
2. In the following program, plz explain
Dim tempA As Variant
Dim tempB As Variant
Public AvaL, BvaL, CvaL As Integer
Public FlagA, FlagB, FlagC As Integer
Private Sub cmd_1_Click()
graphA.Show
End Sub
Private Sub cmd_2_Click()
graphB.Show
End Sub
Private Sub cmd_3_Click()
graphC.Show
End Sub
Private Sub Form_Load()
With MSComm1
[B].CommPort = 1
.InputLen = 1[/B]
[B].InputMode = comInputModeText
.SThreshold = 1
.RThreshold = 1[/B]
.Settings = "9600,n,8,1"
[B].Handshaking = comNone
.PortOpen = True[/B]
End With
FlagA = 0
FlagB = 0
FlagC = 0
End Sub
[B]Private Sub MSComm1_OnComm()
Dim Buffer As String
Select Case MSComm1.CommEvent
Case comEvReceive
Buffer = MSComm1.Input
Call HandleInpuT(Buffer)
End Select
End Sub[/B]
Function HandleInpuT(ByVal DataBuf As String)
If tempB = [B]CInt(&HAB)[/B] Then
Select Case tempA
Case [B]CInt(&HB1)[/B]
txtTemperature = ((Val(Asc(DataBuf) + 81 + Rnd)) / 10)
Case [B]CInt(&HB2)[/B]
txtBreath = Val(Asc(DataBuf) - 100)
Case [B]CInt(&HB3)[/B]
txtCO2 = (Val(Asc(DataBuf) + Rnd)) * 500
End Select
End If
tempB = tempA
tempA = Asc(DataBuf)
End Function
Private Sub Timer1_Timer()
AvaL = Val(txtTemperature)
BvaL = Val(txtCO2)
CvaL = Val(txtBreath)
If AvaL > 265 Then
'MSComm1.Output = "1"
FlagA = 1
Else
'MSComm1.Output = "2"
FlagA = 0
End If
If BvaL > 2000 And BvaL < 9000 Then
FlagB = 2
ElseIf BvaL > 8000 Then
FlagB = 1
Else
FlagB = 0
End If
If CvaL > 20 And CvaL < 40 Then
FlagC = 2
ElseIf CvaL > 39 Then
FlagC = 1
Else
FlagC = 0
End If
If AvaL > 265 Or BvaL > 8000 Or CvaL > 39 Then
Else
End If
End Sub
/CODE]
In these code the highlighted black portion is my problem....
I want to know these:
1. What is MSComm1 and what are COmmport and InputLen....why are they used..what purpose? Also tell about R threshold, S threshold, Handshaking and Port open(what port is open??)
2. WHat is the purpose of this function
Case comEvReceive
End Select
End Sub
in the program??
3. WHat is this Case CInt(&HB2) ? what is done here?
Sorry for the inconvenience.... I dont know VB so after doing my programming in PIC16F877A i gave it to a project centre who designed the code....He didnt explain it properly...SO plz help....
Also if you have any ebooks or so where i can learn about these things plz post....
