Driving Stepper Motor
vhk
Hello
I buy a stepping motor with TYPE 4H4018S0623-1.8DEG.-15V-0.4A-NO. 9549 .
would you tell me how can i drive it? (What kind of transistor is required fo each coil?)
(I used ULN2003 for driving it but not worked.)
thanks
Here is a circuit to drive a 100mA stepper motor. Use a high-power transistor for your 400mA model:
What do you want to use it for? The appropriate drive will change depending on what you use it for.
The title of my project is " controlling stepper motor with RF " (with using microcontrollers)
My stepper motor has 6 wires : two brown(common power wires),yellow,red,blue and white
(Identify the wires to the coils by supplying a voltage on the common power wires and keep one of the other wires grounded while grounding each of the remaining three wires in turn and observing the results...)
thanks for your help
Which microcontroller are you using ?, I had a similar project. I used p1c16f887, unipolar stepper motor and ULN2803AN as the driver.
hi lebohangmaphothoane
maybe atttiny2313 or mega 8 but it's not very important. would you please give me your e-mail that we can do this project together?
what's your RF modules? dose it work?
Like I promised you. so upload the code in PROTEUS and run the program
  • step_step.zip
You can get some ideas from my web page **broken link removed** Briefly, I use a 12c508 cheap little PIC processor to drive the small 6 wire stepper. There are two variants: one with up/down push buttons and the other with an RS232 connection (I like that one better)
