View attachment 67574// LCD module connections
sbit LCD_RS at RB4_bit;
sbit LCD_EN at RB5_bit;
sbit LCD_D4 at RB0_bit;
sbit LCD_D5 at RB1_bit;
sbit LCD_D6 at RB2_bit;
sbit LCD_D7 at RB3_bit;
sbit LCD_RS_Direction at TRISB4_bit;
sbit LCD_EN_Direction at TRISB5_bit;
sbit LCD_D4_Direction at TRISB0_bit;
sbit LCD_D5_Direction at TRISB1_bit;
sbit LCD_D6_Direction at TRISB2_bit;
sbit LCD_D7_Direction at TRISB3_bit;
// End LCD module connections
const unsigned short TEMP_RESOLUTION = 9;
char *text = "000.0000";
unsigned temp;
void Display_Temperature(unsigned int temp2write) {
const unsigned short RES_SHIFT = TEMP_RESOLUTION - 8;
char temp_whole;
unsigned int temp_fraction;
if (temp2write & 0x8000) {
text[0] = '-';
temp2write = ~temp2write + 1;
Lcd_Chr(2,4,'-');
temp_whole = temp2write >> RES_SHIFT ;
if (temp_whole/100)
text[0] = temp_whole/100 + 48;
else
text[0] = '0';
text[1] = (temp_whole/10)%10 + 48;
text[2] = temp_whole%10 + 48;
temp_fraction = temp2write << (4-RES_SHIFT);
temp_fraction &= 0x000F;
temp_fraction *= 625;
text[4] = temp_fraction/1000 + 48;
text[5] = (temp_fraction/100)%10 + 48;
text[6] = (temp_fraction/10)%10 + 48;
text[7] = temp_fraction%10 + 48;
Lcd_Out(2, 5, text);
void main() {
ADCON1=7;
PORTE=0;
TRISE=0;
Lcd_Init(); // Initialize LCD
Lcd_Cmd(_LCD_CLEAR); // Clear LCD
Lcd_Cmd(_LCD_CURSOR_OFF); // Turn the cursor off
Lcd_Out(1, 1, " Temperature: ");
// Print degree character, 'C' for Centigrades
Lcd_Chr(2,13,223); // different LCD displays have different char code for degree
// if you see greek alpha letter try typing 178 instead of 223
Lcd_Chr(2,14,'C');
do {
Ow_Reset(&PORTE, 2 );
Ow_Write(&PORTE, 2, 0xCC);
Ow_Write(&PORTE, 2, 0x44);
Delay_us(120);
Ow_Reset(&PORTE, 2);
Ow_Write(&PORTE, 2, 0xBE);
temp = Ow_Read(&PORTE, 2);
temp = (Ow_Read(&PORTE, 2) << 8) + temp;
Display_Temperature(temp);
Delay_ms(500);
} while (1);
unsigned temp;
char temp_whole;
text[0] = '-';
Lcd_Chr(2,4,'-');
if (temp_whole/100)
else
text[0] = '0';
void main() {
ADCON1=7;
PORTE=0;
TRISE=0;
Lcd_Chr(2,14,'C');
do {
Delay_us(120);
Delay_ms(500);
} while (1);
