DSP applications for building a processor
trinity
We are final year engineering students and want to do a project on "VLSI Design of a DSP processor".Can someone please suggest some feasible application for which a dsp processor can be designed.
Are you planning to make it using FPGA or ASIC?
for u squintz
VLSI- Very large scale integration (Its a technique used to fabricate ICs )by integrating a large no of components.
DSP- Digital Signal Processing. Used to basically sample analog signals and condition them to transform them to digital form for processing.
Re: for u squintz
and FPGA stands for: Field Programmable Gate Array.
ASIC: Application specific Integrated Circuit.
Will you write the cods using VHDL or Verilog?
is anyone working on this project?
we are working on the following project topic --"VLSI Design of a general purpose DSP processor" . if any of u can identify with this topic then please reply so that we can discuss the challenges that we will be requiring to face.
Re: is anyone working on this project?
Why don't you check the site of Xilinx
Try to have a look on the application notes, it may help.
keep in touch with me, I'm interesting in your project.
Curious, why use VHDL and FPGAs to do a VLSI project? I believe DSPs require extremly precise resistors in the ADC and DAC which are not typically found in FPGAs as far as I know... or is there some kind of trick to get around this?
verilog hardware definition language -- used to setup programmable logic chips such as FPGAs
ADC -- analog to digital converter
DAC -- digital to analog converter
Or do you mean you're making FPGAs and not programming them? I can see that... that makes more sense
We are initially doing the VHDL part. About fpga's we'll bother later. we are planning to first design it in VHDL. and then merely testing the design.
By the way can anyone tell me where i can read about general architecture of DSP processors. Any site which can guide me to find good features from all the commercially available ones?
happy hunting
are 'very well tried' wishes in order since we think ur q still remains unanswered.
I suggest u implement a fast high precision calculator using a dsp processor. or a simple processor for character recoginition or something which is used to compress wave files(shivraman's proj was this)
Thanks Sherif welsen. The sites are helpful. We are presently busy preparing a synopsis for the project. shall let u know about the details once it is done.
we are planning to use fpga for the final design,so we needed to know whether, after implementation we will need to load an operating system for the processor to analyse its working......
any ideas?
