dsPIC30F4011 pgd & pgc share pin with spi & i2c
zidanelam
Hi
I would like to know how to debug dsPIC30F4011
pin 25 - PGD/EMUD/U1TX/SDO1/SCL/RF3
pin 26 - PGC/EMUC/U1RX/SDI1/SDA/RF2
as you can see, pgd is sharing the same pin with sdo1 and scl
I'm aware there is EMUD1 and EMUC1 for ICD, how should i connect if i want to debug it without conflicting SPI communication?
Or is there any suggestion?
Use a bigger chip whilst you develop the code and then switch to the intended target.
Or, you can probably get a special chip with additional pins for debug.
