Hello. For our design project at the U, we keep running into the problem of getting the hardware to work. The problem is that everything else on the ICD2 and the dsPIC30F4011 seems to work, except that the verify will fail after programming- and it seems to be a completely random hit or miss thing to get it to work.
-I never ran into this problem when I was working on our first assignment with it
-Occasionally I will build a circuit (bare bones all the time) and it will work perfectly without fail but...
-if we do something like unplug the ICD2 and plug it into another PC beside us then it the problem will reappear and WON'T go away even if we plug it back into the first PC
-if we sit there for hours on end continuously programming it over and over again, occasionally, it will pass the verify
-we have gone through 6 different ICs
-we have used 2 different ICD2s
-we have used the socket universal programmer and it fails the verify too
-this does not happen when we use another PIC like the PIC18
-We are working from behind VMWare on a Linux system because that's what the lab has for MPLab, but we have also tried it on Windows Laptops in our group but my group members' laptops are funky in that the USB doesn't seem to behave consistently properly even with a flash drive and someone else has Windows Vista which is garbage because it does't even recognize the USB device. None of this explains why it fails on the universal programmer which it used to work just fine for on the first assignment.
It's almost like all the chips are damaged or something, except sometimes it will work and work flawlessly. Has anyone ever experienced anything like this? It's become a brick wall in our progress.
