dsPIC30F4011
dsPIC30F4011 Not Seeming To Do Anything
Hey guys. Im working on some code for my midterm tomorrow. Basically, it has to find the duty cycle of an input clock and set the pwm duty cycle to that value.
Here's the code Im using:
#include <p30f4011.h>
int count = 0; // counts number of edges (if 1, if 2, if 3, etc)
float dutyCycle = 0; // holds calculated duty cycle value
float a = 0, b = 0, c = 0; // holds timer values at rise/fall
int main(void);
void __attribute__((__interrupt__)) _IC1Interrupt(void); // ic1 isr
void initIC1(void); // init ic1 stuff and set to capture on rising edge
void initPWM(void); // init pwm stuff
void setPWM(float); // set pwm1 duty register to freq
void delay(long); // delay for i cycles
int main(void)
	//timer
	T3CON = 0x8000; // timer3 control register
	TMR3 = 0; // clear timer3 register
	PR3 = 0xFFFF;
	IPC1bits.T3IP = 5; // timer3 interrupt priority
	IEC0bits.T3IE = 1; // timer3 interrupt enable
	IFS0bits.T3IF = 0; // timer3 interrupt flag
	// pin cfg
	TRISB = 0x00; // make port B all outputs
	TRISE = 0x00; // specifically make E0 an output
	ADPCFG = 0xFF; // disable ADC on portb
	initPWM(); // initialize pwm regs
	while(1) // loop
		if (count == 0 && IEC0bits.IC1IE == 0) // if we're starting fresh
			initIC1(); // 		   		(count = 0, and IC1 is off, enable IC1
		if (dutyCycle > 0)
			setPWM(dutyCycle); // set pwm freq to dutyCycle (updated in ISR)
		PORTB++; // inc portb (just to show activity)
		Nop();
		if (PORTB == 0xFF)
			PORTB = 0; // rollover at max
		delay(10000);
	return 0;
void __attribute__((__interrupt__, __auto_psv__))_IC1Interrupt(void)
	if (count == 0)
		a = IC1BUF; // store timer value in a
		IC1CON = 0x02; // change IC to store on falling edge
		count++; // increment count
	else if(count == 1)
		b = IC1BUF; // store timer value in b
		IC1CON = 0x03; // change IC to store on rising edge
	else if(count == 2)
		c = IC1BUF; // store timer value in c
		count = 0; // reset count
		dutyCycle = ((b-a)/(c-a)) * 100; // calculate duty cycle
		IEC0bits.IC1IE = 0; // disable IC1
	IFS0bits.IC1IF = 0; // clear interrupt flag
void initIC1(void)
	IC1CON = 0x03; // change IC to store on every rising edge, tmr3 contents captured
	IEC0bits.IC1IE = 1; // enable IC1 interrupts
	IPC0bits.IC1IP = 7; // set IC1 priority
	IFS0bits.IC1IF = 0; // clear IC1 interrupt flag
void initPWM(void)
	PTPER = 1600;
	PWMCON1bits.PEN1L = 1; // enable pwm1L pin
	PWMCON1bits.PEN1H = 1; // enable pwm1H pin
	OVDCONbits.POVD1L = 1; // output on pwm1L controlled by pwm generator
	OVDCONbits.POVD1H = 1; // output on pwm1H controlled by pwm generator
	PTCONbits.PTEN = 1; // pwm time base is on
void setPWM(float freq)
	freq = freq * 4000; // multiply by 4000
	PWMCON2bits.UDIS = 1; // updates from duty cycle and period registers are disabled
	PDC1 = freq; // move frequency into pwm duty cycle register 1
	PWMCON2bits.UDIS = 0; // updates from duty cycle and period registers are enabled
void delay(long i)
	long abc;
	for(abc = 0; abc < i; abc++)
		Nop(); // kill a cycle
Ive added PORTB++; to the main loop just so that I can see activity on the port (on an LED board - a board with a driver and leds to indicate the status of each bit), but when I program and take MCLR to Vdd, I get 0x01 on PORTB and it never increases. But in the sim, it works fine. What am I doing wrong?
Im using FRC w/ PLL x4 and the internal fast RC for a clock, a PICKit2, and MPLAB with the C30 compiler.
EDIT Also, if I load up the PICKit2 as a debugger, and animate, it works properly (or the LEDs count anyways - more than before). If I click Run though, the Output window shows:
Running Target
PICkit 2 Ready
Target Halted
and all the LEDs come on (indicating FF on portb)
EDIT 2 With this code, the LEDs count as I expect them to, so my hardware is correct at least
int main(void);
void delay(long i);
int main(void)
	TRISB = 0x00;
	ADPCFG = 0xFF;
	while(1)
		PORTB++;
		if (PORTB == 0xFF)
			PORTB = 0;
		delay(10000);
void delay(long i)
	long a;
	for (a = 0; a < i; a++)
		Nop();
Fixed my own problem. With these three lines:
I was enabling an interrupt but I didnt have an ISR to handle it. Doh! Case closed.
