djsfantasi
This routine is interrupt driven, and will detect either a short or long button press. It's return value is bit encoded and as such it is possible that both a long and short press can be detected. They are valid, since the press is debounced.
The code is not optimized, but written for instructional use. The majority of variables are Boolean, to keep track of the state of the button. The listing is of an entire sketch, to show the global definitions, setup and use of the function.
C:
#define HALT while(true);
#define STATE_NORMAL 0
#define STATE_SHORT 1
#define STATE_LONG 2
const int LED = 13;
// Button input related values
static const byte BUTTON_PIN = 2;
//static const int STATE_NORMAL = 0; // no button activity
//static const int STATE_SHORT = 1; // short button press
//static const int STATE_LONG = 2; // long button press
volatile int resultButton = 0; // global value set by checkButton()
void setup() {
Serial.begin(9600);
pinMode(LED,OUTPUT);
digitalWrite(LED, LOW);
Serial.println(F("Initializing Button pin"));
pinMode(BUTTON_PIN, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(BUTTON_PIN), checkButton, CHANGE);
Serial.println(F("Button pin initialized"));
void loop() {
int longButton=0;
int count=0;
while (true) {
switch (resultButton) {
case STATE_NORMAL: {
/* Serial.print(".");
count++;
count = count % 10;
if (count==0) Serial.println(""); */
break;
case STATE_SHORT: {
Serial.println("Short press has been detected");
digitalWrite(LED,HIGH);
delay(1000);
digitalWrite(LED,LOW);
resultButton=STATE_NORMAL;
break;
case STATE_LONG: {
Serial.println("Button was pressed for long time");
delay(3000);
longButton++;
break;
if (longButton==5) {
Serial.println("Halting");
HALT;
void checkButton() {
* This function implements software debouncing for a two-state button.
* It responds to a short press and a long press and identifies between
* the two states. Your sketch can continue processing while the button
* function is driven by pin changes.
const unsigned long LONG_DELTA = 1000ul; // hold seconds for a long press
const unsigned long DEBOUNCE_DELTA = 30ul; // debounce time
static int lastButtonStatus = HIGH; // HIGH indicates the button is NOT pressed
int buttonStatus; // button atate Pressed/LOW; Open/HIGH
static unsigned long longTime = 0ul, shortTime = 0ul; // future times to determine is button has been poressed a short or long time
boolean Released = true, Transition = false; // various button states
boolean timeoutShort = false, timeoutLong = false; // flags for the state of the presses
buttonStatus = digitalRead(BUTTON_PIN); // read the button state on the pin "BUTTON_PIN"
timeoutShort = (millis() > shortTime); // calculate the current time states for the button presses
timeoutLong = (millis() > longTime);
if (buttonStatus != lastButtonStatus) { // reset the timeouts if the button state changed
shortTime = millis() + DEBOUNCE_DELTA;
longTime = millis() + LONG_DELTA;
Transition = (buttonStatus != lastButtonStatus); // has the button changed state
Released = (Transition && (buttonStatus == HIGH)); // for input pullup circuit
lastButtonStatus = buttonStatus; // save the button status
if ( ! Transition) { //without a transition, there's no change in input
// if there has not been a transition, don't change the previous result
resultButton = STATE_NORMAL | resultButton;
return;
if (timeoutLong && Released) { // long timeout has occurred and the button was just released
resultButton = STATE_LONG | resultButton; // ensure the button result reflects a long press
} else if (timeoutShort && Released) { // short timeout has occurred (and not long timeout) and button was just released
resultButton = STATE_SHORT | resultButton; // ensure the button result reflects a short press
} else { // else there is no change in status, return the normal state
resultButton = STATE_NORMAL | resultButton; // with no change in status, ensure no change in button status
