Dynamo powered radio.
louishenri
Hey I need some information on how to build a dynamo powered radio.the radio currently works on 8 1.5v tipe D batterys.Any info is welcome.If possible a circuit diagram.
THANK YOU
No diagram needed - just ten D type NiMh batteries (you need ten to replace eight normal batteries), fed through a rectifier. Feed the rectifier from the dynamo, making sure the polarity is the correct way round (or it won't work, the rectifier stops it).
I don't see why you should need any batteries.
For a start, without a charging circuit or at least a current limiting resistor, the batteries would soon overcharge.
All you need is a voltage regulator, such as the LM7812 on the output of the rectifier.
You might need to add some overvoltage protection, depending on the maximum output voltage from the dynamo.
Yes I am, he didn't say anything about it being hand cranked, I thought it was going to be on a bike.
Still, didn't think that was important, my mum's bike has dynamo lights which go out when she stops, except for a capacitor in the rear light which keeps the LEDs flashing for a minute or so.
Wouldn't keep a radio going though - but we're just speculating anyway, the OP has never clarified his question.
