Eagle CAD manual routing question
earckens
I am trying to connect the two via's that currently are connected with an airwire (see picture).
However I get a yellow X-mark on the destination via when doing a bottom trace between them.
How to properly connect a bottom trace between both via's?
Eagle v7.6.0
  • lab PSU LM723 v12a.brd
Solved:
1. starting from the upper right airwire/via trace bottom track to lower left track at R5, connect to upper trace (without via). Add via to connect lower and top trace at R5.
2. the ground polygon plane automatically will make way for that new bottom trace.
I was going to suggest that you need to "rebuild" (in EasyEDA terms, I've totally moved on from my old version of Eagle). Glad you figured it out.
