Yes, they do not need an earth ground. A proper dipole which is 1/2λ in length will give ~20db better far-field signal strength than a 1/4λ with the mickey-mouse ground consisting of only the PC trace.
This applies equally to the receiver as well as the transmitter. Also, remember that both antennas need to be polarized vertically, or horizontally. Crossing their polarizations creates a 25db loss.
I'm only planning to go 5 to 10ft. So, my antenna should be based on that.
Ok, then use a wet noodle![]()
We discussed the rules for 310 and 433 MHz in this thread: https://www.electro-tech-online.com/threads/where-are-310mhz-and-433mhz-rules.101312/
RF can be funny stuff!Disclaimer: I'm no RF expert.
To get an idea of what works well, think in terms of wavelength.The lower the frequency the higher capacitance the ground plane needs to be, meaning it needs to be larger.
Exactly!At UHF I would've thought a PCB ground plane or even a battery would be fine.
At much lower frequencies, such as longwave, mediumwave and shortwave frequencies the usual "earth" connection is a mat of buried wires radiating radially from the base of the antenna mast.You only need a real earth connection at low frequencies.
