Nicksan said:Does this circuit work on a breadboard?
I just tried it and nothing, except the piezo kept going off, I checked it and made sure the Transistor was good and still nothing.
joecool85 said:Sort of, ideally it will never be submerged. I'm putting mine next to my sump pump, and unless I have a sump failure (it does happen every so often) they won't get wet. But the few times they do shouldn't create a lot of corrosion. Also, even with corrosion, this circuit should function fine as it isn't horribly critical what the resistance is between the two probes as long as there is some. I tried it with filtered water from the sink and it worked still! Heck, even moist fingers set it off.
joecool85 said:While I agree about the floater being better for multiple fluid types, I designed this for water and only water. Hopefully that would be the only fluid flooding out my basement.
Leftyretro said:Of course water is probably all your basement will ever see, but think about long term reliablity and ease of testing, fewest components, etc. This kind of application can help save you a ton of $$ in damage and the the sensor portion needs to be as failsafe as you can come up with. I still vote the simple float switch if it was my basement. Basements are rare in California but sump alarms are common.
Now what I need is an earthquake alarm circuit that gives about 5 mins warning of a big one![]()
Lefty
Leftyretro said:{snip}I still vote the simple float switch if it was my basement. Basements are rare in California but sump alarms are common.
{snip}
Lefty
Rolf said:So if you don't have a sump pump; where do you find a float switch that operates in a (aprox) 0.01" of water? After all you do want an alarm that senses the very appearance of water.
