helloleong
Im using Xicor x25650 EEPROM. But i found the chip has 2 problem.
First is the WIP bit problem. Initially i keep on check the WIP bit by the MCU, if write cycle finish only continue to the next instruction. After few 10 times i read the WIP bit, then the WIP bit get spoilt. Then i change to delay 5ms only the next write instruction ok.
Second is when the eeprom dint not power on for long time, after power on the 1st 8 bit will be fail to read, but the next read and write instruction is ok. So i have to read the first data twice to avoid first data miss read.
Did anybody face this problem also?
Thanks you.
Thanks you.
