Gregory
How do you tell the difference between a EHT and a EHT with a back to back Diod's if you do not have any specks.
How do you test the EHT with back to back Diods to find out if it is faulty.
On a normal EHT you can use a shorten turns tester. But on a Diod one it dos not work.
Can power be supplied by means of a Veriac to the EHT that is off the board and measure the voltage on each turn.
