Hi all. I've been searching for some solid electronic hobbyist forums that could lend me some advice for my senior design project, and I found myself here. I'll probably end up using this thread as a build log as well should it get enough attention. So here goes...
My group is making a standalone device that will read an audio signal from a vinyl via stylus, digitize it, and send to a PC where it will then be converted to a hi-fidelity audio format, most likely .flac. I realize we're not exactly reinventing the wheel here, but it seemed like a fun project and our professor approved it, so why not. A few extra tasks we came up with to make it sr. design worthy are:
Currently, we're still in the research phase, but we really need to buy parts in the next week or two so we can start playing around with something. My assignment right now is figuring out what is needed to amplify/attenuate/filter the analog signal before we digitize it. For now, our plan is to use an MSP430 (not sure exactly what model, but it's being loaned by my professor) to handle the A to D function. Scoping up to the stylus of our MONO record player shows a voltage signal that seems to average around 5-7V w/ spikes around 9-10V. I was surprised to see a voltage this high just from the stylus. It looks like I'll need to attenuate instead of amplify to bring it to suitable levels. And that's basically as far as we are currently. If you read all the way through this, I appreciate all the interest and any help you can give.
tl;dr: Though I scoured the spec sheets, I couldn't seem to find what input voltage is needed for ADC on a Ti MSP430 board. I'll get the exact model asap. Also, what are my options as far as audio signal attenuation?
Thanks![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
- DIY deck assembly - this means we'll be making our own motor control system w/ feedback
- Line-in level LED array - This will serve as a crude line-in level meter so we can see if our analog signal is too low or clipping
- DIY amplification/filtering of analog signal - this is the part I am most concerned about. I know audio signal are very sensitive to noise and require careful consideration to accurately recreate. Having no experience in this area, I'm sure most of my questions will stem from this.
