Hi all,
I am currently doing my final year project which is "mineral discrimination using electromagnetic waves". My idea is to build the electromagnetic waves detector that can receive the electromagnetic waves which had been manipulated by conductivity property of a mineral.
Since electromagnetic waves have the property of frequency, I plan to build the frequency detector that can convert the electromagnetic waves with certain frequency value to respective DC voltage value. From the variation of DC voltage produced at the output, I can classify each DC voltage value to respective mineral. I have gone through the forums that discuss about frequency detector circuit. One of the circuit provided by bacterozoid at this link
Frequency Detector Broken Remote
and the other circuit provided by trikebuilder at this link
I plan to use the circuit provided by bacterozoid for my electromagnetic waves detector circuit with a little bit modification on butterworth filter part. I plan to have cut off frequency larger than 400Hz. For the input to the circuit posted by bacterozoid, I plan to replace it with either electromagnetic waves input or radio frequency input instead of audio input. According to bacterozoid, if I want to receive electromagnetic waves as the input, I need to hook an antenna at the input. But there might be the possibility that the circuit does not work at all since bacterozoid's circuit is spesifically designed for frequencies in the audible range (under 2KHz). The possibility of circuit failure might be occur due to those electromagnetic waves which are higher in frequency.
I am quite confused now . Can anyone help me with my project? Or can anyone suggest on how to build electromagnetic waves detector? Can I just proceed with the frequency detector as I mentioned before?
Thank you very much for any help
