Optikon
Ok so I'm currently studying techniques to model, analyze and reduce electronic circuit noise. I'm still very much an amateur in this area and I have a fundamental question. Can someone please clear up the following argument in noise modeling?
Consider a resistor component and the thermal noise component.
The noise model can be a noiseless resistor in series with a noise voltage source or in parallel with a noise current source. In the case of noise voltage, Et = SQRT(4*k*T*R*B) where B is bandwidth of interest, T is temp, k is boltz const and Et is the mean noise voltage.
Now the question. If one considers a very large R and a very large bandwidth, the noise voltage will be accordingly high. If 2 such resistors are connected in parallel (with no other source present) an intuitive thought would be that a noise current will circulate around them(assume uncorrelated).
This would be incorrect! according to the literature and common sense. This situation does not represent a real power source. The thermal noise is physically caused by thermal agitation of the electrons and that acts against the resistance to generate the noise voltage at the terminals but a NET current flow will not exist into and out of the component.
This I understand..
Now think about what happens to a floating input gate of a high impedance circuit. We can take a high inp impedance circuit like say an electrometer type amplifier, and place our same resistor in series with an input and power the amplifier but leave the input circuit floating. Invariably we all know that noise can cause the amplifier to saturate to one of the rails quite easily or even jostle back and forth between rails.
But for this to be the case, a REAL current (albeit VERY VERY small) must have flowed into the gate of the input circuit. I mean charge can accumulate on the high impedance but, what switches the input will actually be the voltage due to charge and a small current(moving charge) and we say "well the amplifier turned on because of noise on the floating input."
So is a current flowing or not!? Can the thermal energy of the electrons in the resistor actually get bumped out of the component and into the gate in such a quantity that it can turn it on? Or is that charge not part of the charge that enters the gate and these two are somehow distinguishable?
Anyone shed some light???
THANKS!!!!!!!!
![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
This I understand..
THANKS!!!!!!!!
