Hi Guys,
I'm hoping someone can help me fine the right product as I don't do much with electronics/pneumatics in my design work. Basically I have a very low pressure air pump which needs to feed into a manifold with 4 or 5 exit ports (ideally 5). Each manifold needs to be electronically controlled, so press button 1 to open manifold one whilst all others remain closed. Size wise it needs to be fairly small (150mm x 75mm would be ideal).
A software engineer will write the program and design board for opening the ports, I just need the hardware. Is there anything off the shelf that would be suitable? RS components have many manifolds but I'm not sure if these are suitable for use with an air application!
Any help would be appreciated!
Crappy picture to help illustrate...
Cheers
Tom
Cheers
Tom
