Hi, I'm almost completely ignorant of electronics but want to build a device to induce an electrorheological effect on a diesel fuel line. I need to generate a field of 1kV/mm between two mesh electrodes 10mm apart which will be located within the fuel line. This field would be around 0.1 W in power. Any thoughts about generating this field using the power available under a car bonnet? If this works the fuels viscosity is reduced aiding combustion. Thanks
