Hero999 said:My first question of course is why do you want to do this?
Frequencies below 20Hz are useless for audio.
I don't understand what you are trying to say. The fundamental frequency of a 10Hz square wave is, not surprisingly, 10Hz. The amplitude of the Nth harmonic is 1/N times the amplitude of the fundamental. The nearest harmonic to 100kHz will be less than 0.0001 times the amplitude of the fundamental.Sceadwian said:I believe the rise and fall times of the waves are key to brainwave and Schuman resonance frequencies, IE true RF sine waves. Square waves on the same frequencies aren't even registered on most instruments that are able to receive them because of the rise and fall times. The rise and fall time of a 555 is what, 10u seconds? That's 100khz. Even if the ultimate frequency the 555 is producing is only 10hz, the transitions occur at 100khz, no reception occurs.
