em-18 rfid reader and pic microcontroller
Hello,
You don't require IC MAX232.
EM-18 RFID Reader Module works on 5v and PIC 16F877A is also a 5V microcontroller.... so you can directly connect TX of Reader module to RX of Microcontroller.
Try the following link, it will help you.
Interfacing EM-18 RFID Reader Module with PIC Microcontroller
Circuit Diagram :
MikroC Code :
// LCD module connections
sbit LCD_RS at RB2_bit;
sbit LCD_EN at RB3_bit;
sbit LCD_D4 at RB4_bit;
sbit LCD_D5 at RB5_bit;
sbit LCD_D6 at RB6_bit;
sbit LCD_D7 at RB7_bit;
sbit LCD_RS_Direction at TRISB2_bit;
sbit LCD_EN_Direction at TRISB3_bit;
sbit LCD_D4_Direction at TRISB4_bit;
sbit LCD_D5_Direction at TRISB5_bit;
sbit LCD_D6_Direction at TRISB6_bit;
sbit LCD_D7_Direction at TRISB7_bit;
// End LCD module connections
void main()
char i, rfid[13];
Lcd_Init(); // Initialize LCD
Lcd_Cmd(_LCD_CLEAR); // Clear display
Lcd_Cmd(_LCD_CURSOR_OFF); // Cursor off
Lcd_Out(1,1,"RFID Tag Reader"); // Write text in first row
UART1_Init(9600); // Initialize UART, 9600 baud rate
rfid[12] = ''; // String Terminating Character
while(1) // Infinite Loop
if(UART1_Data_Ready()) // If UART Data Ready
for(i=0;i<12;) // To Read 12 characters
rfid[i] = UART1_Read();
i++;
// Check For Errors
if((rfid[0] ^ rfid[2] ^ rfid[4] ^ rfid[6] ^ rfid[8] == rfid[10]) && (rfid[1] ^ rfid[3] ^ rfid[5] ^ rfid[7] ^ rfid[9] == rfid[11]))
Lcd_Out(2,1,rfid);
else
Lcd_Out(2,1,"Error ");
Source :
https://electrosome.com/em-18-rfid-module-pic/
